Is there is any way to create a query for multi level relationship
skrisnamoorthy
Is anyone know how to create a query for multi level relationship
For Eg:
Level : 1
Level : 2 (related Item)
Level : 3 (related Item)
Level : 4 (related Item)
How to retrive the list of Level 4 items from Level 1 (Using ID) from a Query?
Shankar
mrump
(To:skrisnamoorthy)
Hi Shankar,
unfortunately there is no way to receive this information using a query.
This is only possible using a report started for your level 1 item(s).
Note:
The relationship filter in the query designer only allows you to filter for "Level 1" items that have a relationship to "Level 2" item which fulfill certain criteria.
HTH Matthias
mrump
(To:skrisnamoorthy)
Hi Shankar,
Note:
HTH Matthias
KaelLizak
(To:mrump)
Hello Shankar,
Matthias is correct:
  • ​Not available because the functionality does not exist
  • Reported to R&D as enhancement RFC 145864 via CS88090
  • Please contact PTC Integrity Support if you wish to be associated with this enhancement request
Kael
Kind Regards,
Kael Lizak
Hi Shankar,
I did a lot of researched and developed already some add-on solutions in the area of tracing and relationship trees.
I am interested to know which use case is behind your question. What do you try to accomplish with such a complex query?
Volker
