Need ability to authenticate Integrity users from multiple top level LDAP user domains
This would apply for
Active Directory
Novell eDirectory
others ...
6 Comments
Aquamarine
This would also be great if in LDAP System is used like DirX which allows to have a Forest of LDAP Domains (per location) which are combined to one general for the company (which can't be used for placing requests).
Gravel
Status changed to: New Idea
Have you considered using LDAP-referrals ?
If you're using it & faced any shortcoming, can you please describe the entire use for PTC ILM Security team to gather additional details ?
Gravel
I have some more information to share in this regards.
There are couple of scenarios for setting up authentication over multiple LDAP domains in ILM.
  1. Subdomains (child-level domains) in the same LDAP forest (i.e. top-level domain) – which is supported by PTC
    i.e. ldap.host.1=sub.domain.com
          ldap.host.2=anothersub.domain.com
    Refer supported article at : https://www.ptc.com/en/support/article?n=CS117076&language=en&posno=3&q=user.dn.2&ProductFamily=Inte...
  2. Domains across multiple LDAP forests (i.e. multiple top-level domain) – which is not supported by PTC.
    However, some customers have been using Microsoft Active Directory Application Mode (ADAM) to address their authentication requirements.
    Refer supported documentation article at : https://docs.microsoft.com/en-us/previous-versions/windows/it-pro/windows-server-2003/cc738377(v=ws....
I believe, scenario # 2 mentioned above matches with the requirement described in Idea.
Regular Member
From ZF perspective this idea is outdated and it could be  closed.
Meanwhile we have a working multiple LDAP solution in place. This solution is based on the support article mentioned in the previous comment in scenario 1.
Gravel
@bklitzsch Thanks for the confirmation.
I'm now closing this idea.
Gravel
Status changed to: Alternate Solution
