PTC Jenkins Plugin Integration Issue
spadaki
2-Guest
The issue is regarding the configuration of PTC With Jenkins
The tools used are
1) MKS Integrity Client 2009
Build: 4.10.0.9665
Service Pack: 007-01
2) Jenkins version 1.599
3) PTC Integrity CM - Jenkins Plugin : 1.31
The link "https://wiki.jenkins-ci.org/display/JENKINS/PTC+Integrity+Plugin" depicts the configuration process. The integrity hpi file is uploaded
manually. Upon success, proceeding with the configuration there is an error that occurs while testing the connection. The entries include
hostname
port
username
password
Error: Failed to establish connection!
Error Log
Mar 04, 2015 4:53:27 PM FINE IntegritySCM
Testing Integrity API Connection...
hostName: w******8
port: 9001
userName: s*****r
password: YK****AE=
secure: false
ipHostName:
ipPort: 0
Creating Integrity API Session...
Mar 04, 2015 4:53:28 PM SEVERE hudson.scm.APISession create
API Exception caught...
Unexpected HTTP status: Internal Server Error
Mar 04, 2015 4:53:28 PM FINE IntegritySCM
returned exit code -1
APIException
1 ACCEPTED SOLUTION
pmerkle
(To:spadaki)
when creating a PTC Session via the Integrity Java API an APIException can be thrown for serveral reasons:
1. Wrong hostname or port
2. Incompatible API version
3. Wrong user name or password
For further investigation it would be helpful if you add the complete server.log file as attachment to your question.
Peter
6 REPLIES 6
KaelLizak
(To:spadaki)
Have you tried connecting to the server from the same host that the Jenkins integration is installed on using the GUI or web UI with the same credentials? If it does work, I would investigate the API configuration of the Integrity server. If it doesn't work, I would suggest:
  • Making sure the credentials are valid
  • Making sure that workstation can connect to that server on that port (general network connectivity, firewall rules)
I hope that helps.
Kael
Kind Regards,
Kael Lizak
Senior Technical Support Engineer
PTC Integrity Lifecycle Manager
pmerkle
(To:spadaki)
I don't think that the newest version (1.31) of the PTC Adaptor for Jenkins works with MKS Integrity Client 2009.
The lowest Integrity version the plugin supports is Integrity 10.3.
Peter
Hi Peter
First of all, thanks for the quick reply
Which version of PTC adaptor (Integrity Hpi) plugin file would be suitable for MKS Integrity Client 2009?
pmerkle
(To:spadaki)
I have found the following statement on the web page
https://wiki.jenkins-ci.org/display/JENKINS/PTC+Integrity+Plugin#PTCIntegrityPlugin-PluginforUnsupportedConfigurations
under the section “Plugin Unsupported Configurations”:
“With the release of integrity-plugin 1.29, versions older than Integrity 10.5 are no longer supported. A special one off version 1.31-4.10.9049 has been created for users who want to take advantage of the recent fixes but need more time to migrate from Integrity 2009 SP6, SP7, 10, 10.1, 10.2, 10.3 and 10.4. There will be no more fixes provided for configurations older than Integrity 10.5.”
I hope that will help you …
Peter
KaelLizak
(To:pmerkle)
Hello Sujith,
Did Peter's answer provide you with the information you required? If not, please let us know what you still need. If it did answer your question, please mark the appropriate response of Peter's as Correct Answer by clicking on that button at the bottom of the appropriate response. From the bottom of any given post, you can also select Actions --> Mark as Helpful if a post was somewhat useful, but didn't get you a complete answer.
The reasons we ask you to do this are because 1) someone else searching for a similar issue can more easily identify what you found useful in the thread, and 2) it recognizes Peter's contribution to the discussion.
Kael
Kind Regards,
Kael Lizak
pmerkle
(To:spadaki)
Peter
