PTC SCM and Sparx EA integration
SOLVED
Newbie
Has anyone used the Integrity SCM capability to version control their Sparx EA project/models?
If so, how does this work and how do I connect EA to the Integrity repository?
Thanks!
Kris
1 ACCEPTED SOLUTION
Re: PTC SCM and Sparx EA integration
It does exist and I got it working with the help of Cletus D'Souza,
4 REPLIES 4
Highlighted
Hello Kris,
Are you looking for an integration between Source Integrity and Sparx EA? To my knowledge, such a thing does not exist. CS84749: Support for item integration with Sparx Enterprise Architext in Integrity and CS85887: How to integrate Integrity Configuration Management functionality with Sparx Enterprise Arc.... Having said that, apparently you should discuss this with an Account Manager and/or Global Services, as they may be able to assist.
Kael
Kind Regards,
Kael Lizak
Senior Technical Support Engineer
PTC Integrity Lifecycle Manager
Hello Kris and Kael,
I need the solution you got from Cletus, how can I get it?
Hello Laurent Lawton‌,
If it's an FDO (Field Deployed Object), you'll have to go through your account manager.  There is no "core" integration with Sparx Enterprise Architect.
Kael
Kind Regards,
Kael Lizak
