Permission to close empty Change Packages
0 Kudos
Currently you need Admin rights to close an empty Change Package. What is the purpose of this restriction? Also Project Managers should be allowed to close empty Change Packages.
1 Comment
Peridot
In 11.1, there is a new permission added called "ManageEmptyChangePackage".  If a user has this permission, they will be able to discard or close empty change packages created by other users. This permission has to be granted at the mks:si level as an empty change package has no project to check for permissions.
