Possibility to sort and filter within Test Result Editor.
Within the Test Results Editor the possibility to sort and filter fields shall be available.
The only possibility to filter is regarding "test result", but all related fields shall be available for filtering.
3 Comments
Alexandrite
Hello Deepak,
In what basis you want filter there because in Test Result Editor Window there is only a single thing that is Verdict and that is already configured. Please let us know more on the same ? I am not getting what requirement you exactly have ?
Thanks and Regards,
Kapil Jain
Marble
we are also interessted in an enhanced filter.
Use case: Often not only single Test Cases are linked in a Test Session, but whole Test Suites are linked.
Our users want to set a filter, which hides all Headings.
Another use case: We implement a workflow for Test Case.
In the Test Result editor a filter would be helpful, which hides all Test Cases, which are not in a appropriate state.
Regards
Markus Kießling
Participant
Hi Kapil,
I'm having the same issues which Markus stated above. As of the now the Test Result Editor only have the options sort the test cases based on the verdict, We Would require most of the fields which available in the test case for the better understanding. As Markus stated a test session contains more test cases and there is no option available to sort based on the State, Maturity method and other related fields which is available in the Test Case on the Test Result Editor .
Afsal Ashraf
