Possibility to validate date fields
In PTC Integrity we do not have an inbuilt functionality to validate date fields.
There should be possibilities to set rules to validate date fields:
For e.g.:
1)  Comparison of 2 date fields  -> Compare and decide if an entered date value is less than or greater than another already entered date field.
2) Compare a target date value and see if it is greater than created date of an item
3) Compare an issue injection date and validate if it is not a date in the future.
There should be configurations to set logics behind every date field. This would be very much beneficial.
4 Comments
Status changed to: New Idea
In which feature of Integrity Lifecycle Manager do you want to compare the date fields in your use case? E.g. Document Differencing ?
Please provide the information so as to further comment on this.
Status changed to: Clarification Needed
Visitor
We need this as an admin configuration. There should be a possibility in simple date fields used in Integrity workflow items.
Eg: Extend constraints with such a feature to compare date fields. Currently this is not possible as mentioned originally.
As a result, the end user should be validated for the values that they are entering in the date fields as per the logics that is set.
Thanks for the clarification.
