Prevent query view tabs with the same name show up number of times, reuse them instead.
0 Kudos
In a case where you use a dashboard item to have a user execute a query instead of having he/she execute it from list of queries, each time a user clicks a certain query, additional view tab with the same name that contains the query result appears. The user will often see many view tab with the same name and forget which one contains the latest result.
Integrity should be designed to reuse the tab in stead of popping up a new one if a content is based on the same query result.
2 Comments
If you are not using a Floating View then a new tab always opens in the end so you can identify which is the latest Tab. I agree this is not easy to use with Floating view.
Can you confirm if the alternate way using Floating View works for you?
Status changed to: Clarification Needed
