Like for Assigned to me I would like to build an historical query to filter issues that at some time in the past has been modified by me.
It is not possible to select the Modified by field in an historical field value filter (maybe because it is a calculated built-in field).
Any workaround known?
HI,
i'm not sure but i think this would help:
Query -> Add Filter -> Field: "History (by User)" -> "- Any Field -" -> "- me -"
Hello Thierry,
Quite interesting question. You are right, I am also not aware of such a "historical modified by" query.
I see the following options if this is really important for your company:
Use the "Item Subscription" functionality, add fields to types where a user can subscribe to an item. With a Query "My Subscriptions" you can then filter the items you have subscriptions for. It would also be possible to store the "Subscribed" users automatically with a trigger. This means that any user who is updating an item will become automatically a subscriber. Then, again, the "My Subscriptions" query would result in what you are requesting.
Are you already using the subscription feature in Integrity?
Volker
HI,
