Regexp support in queries, full-text search
In query creation and document full-text search, there should be capability to enter regular expression patterns.
4 Comments
Participant
you can use oracle text search syntax in queries. This isn't enough ?
Participant
Only when you are oracle, of course.
Amethyst
  • End users will not know which database is used by IT services. This may also change over time.
  • End users are not Oracle or SQL experts, they will most probably not know about Oracle Context Search syntax.
  • Fuzzy search and logical operators might not be specifix enough if you look for specific terms like technical identifiers.
  • Regular expressions are a well-known standard for advanced text search and is supported by Oracle and MSSQL.
Gravel
