SNA to TCP/Ip conversion
jhuntoon
1-Newbie
Has anyone had to convert from SNA to TCP/IP?
Trying to find documentation to accomplish this task.
John
1 ACCEPTED SOLUTION
David_G
(To:jhuntoon)
John:
Sorry for the late reply to this ... but a transition from SNA to TCP should be pretty easy.
  • Configure your remote host system with the necessary hostname/IP & port information on panel 4 of the network configuration.
  • Change the remote environment to use TCP/IP-FTP as the distribution method on panel 3 of the environment config.
  • On the remote system, start the remote communication daemon process using the ICOMCTL command with the same port you specified on the remote system network configuration.
Make sure any firewalls between the host & remote systems allows FTP traffic and the specified port.
At this point, promotions to the remote environment will go over TCP/IP instead of SNA.
Obviously, you can contact Implementer support if you run into any problems.
David
IBM i on Power Systems: For when you can't afford to be out of business! I'm riding in the American Diabetes Association's Tour de Cure to raise money for diabetes research, education, advocacy, and awareness. You can make a tax deductible donation to my ride by visiting https://ptc.diabetessucks.net. You can see where my donations come from by visiting my interactive donation map ... https://ptc.diabetessucks.net/map (it's a geeky thing).
2 REPLIES 2
KaelLizak
(To:jhuntoon)
Hello John,
I'm guessing you are specifically asking about Implementer, since Integrity Lifecycle Manager does not run over SNA. Is that correct?
Kael
Kind Regards,
Kael Lizak
Senior Technical Support Engineer
PTC Integrity Lifecycle Manager
David_G
(To:jhuntoon)
John:
David
