Significant Edit Date changes on restructuring document nodes
0 Kudos
Problem Statement: Significant Edit date or Input revision date of a Node is modified when that node is moved within the document.
Idea: Restructuring document nodes (moving of content item) should not ALWAYS result in significant edit.
Significant Edit must be driven by only Significant Edit fields defined at the Document model of the type.
A way should be provided to control the standard fields like 'contains' to be non-significant change
