Source Integrity - Sharing an archive fails because member is at exp. However member is not at exp.
mlegge
1-Newbie
A co-worker of mine has run into the following issue.  Any suggestions would be appreciated.
Integrity 10, Windows 7
Mel
I have a project with a main branch and a variant branch.  Subsequent to the branch taking place, new files were added to the main branch that now need to be added to the variant branch.  When I View Project Differences the new files are indicated as dropped members in the variant branch.  The procedure I followed to try to add the new files is:
1 – I physically copied the files to the appropriate location in the variant branch sandbox
2 – I selected Add Members on the variant sandbox
3 – I selected Add File
4 – I browsed to the file to be added in the variant sandbox and selected it
5 – I clicked finish on the Add Members Wizard
6 – I clicked OK to create archive
7 – I selected share archive – this is the one I need because these are the same files that must exist in both the main and variant branches.
8 – When I click OK I get the following error message:
<filename>:MKS125475: You are not permitted to lock a revision whose current state is Exp.
1 ACCEPTED SOLUTION
awalsh
(To:mlegge)
The error message appears if there are LockStates set in the Configuration Management policies.  When adding an existing member, sharing the archive, the member is branched.  This branch briefly puts a lock on the head revision.  In this case, the head revision is in a state that does not allow locks.
There are three options:
  • Remove or change the lock states defined
  • Promote the member in the main branch to a state that allows locks
  • Use "Add From Archive" to add the member.  In this case, the member is not branched, so no lock is needed.
2 REPLIES 2
awalsh
(To:mlegge)
mlegge
1-Newbie
(To:awalsh)
Thank you.  My coworker has gone with option 3 and it seems to be working well.
