Source "Configuration Path" vs "Flat Path" obsolescence in Integrity Lifecycle Manager
0 Kudos
  • Support of Configuration Path Syntax
  • Integrity Source Flat Path Syntax should be removed/ deprecated
  • Source Configuration Path vs Flat Path obsolescence
  • Enhance support to address the areas of the product that still use legacy syntax (flat path) instead of the Configuration Path syntax:
    • Change Package Details view
    • Member & Revision Information view
    • Projects view
  •  Receiving the below error while trying to create a normal sandbox using flat path via GUI / CLI:
    • Failed to create sandbox: MKS125443: The subproject <SubProject>/project.pj does not exist (anymore)
For existing reference, please see also CS84840.
