Support the menu-/application-key in Integrity
0 Kudos
  • The menu-/application-key can be used instead of the right mouse button to open a context menu
  • This key does not work in Integrity
See also article CS172132.
2 Comments
Status changed to: Clarification Needed
Could you please check the article id provided CS172132 above? IT says "Error: Case 172132 does not exist". . I would like to go through the details of this case to understand this further.
