Tooltip for Field Values
When a field is defined in a presentation grid then there is the description text of the field available as tooltip (mouseover). This is OK for the usual way of defining a name/value pair in a presentation in the admin client, but once you want to show several values e.g. in a kind of matrix (see figure below) then the description text only goes for the name of the variable (not presented here) but not for the value(s).
I would appreciate it if I could set the description of the field for the field value so that - in the example below the field values on the right - all entries can have a tooltip.
2 Comments
Regular Member
Hi Harold,
Thanks for submitting this idea
I am moving this idea to Future Consideration. We will evaluate the feasibility of supporting this when we target changes in this area.
Regular Member
