Using Change Request and Change Order
blercher
I'm trying the change request and change order functionality for a document in review.
I made a change request that spawns a change order.
Why I cannot enter some id's in the authorizes changes to area (see attachements)?
I have to configure something in chnage order type?
thx
Bernd
Hallo Bernd,
assuming you are using the ALM Solution , then the follwoing has to be set:
  1. you need to be in the "Senior Project Team" group
  2. The project has the flag "Allow Scope Expansion" set to true
  3. The CO state is "In Development"
for sure you can tailor this, but this is the default set in the field definition.
hope this helps
Volker
pmerkle
(To:VolkerEckardt)
I think that the first pre-requisite (membership in group"Senior Project Team" is sufficient, but not required.
Also an Admin user (having all permissions) is allowd to create the relationship between the Change Order and the Document.
Peter
