Versioned contents document id
0 Kudos
when content is versioned, document id in the its related content doesn't exist.
please make it seen.
if can't, let me know why this field doesn't exist.
6 Comments
Status changed to: New Idea
The document id is ambiguous for versioned documents and as you know one versioned content can be associated with multiple versioned documents so document id cannot be shown.
Regular Member
Thank you for your reply
but actually I can't understand how can content can be associated with multiple versioned documents.
does you mean that versioned document 0.1, 0.2...?
if you can, would you please explain the situation?
Thank you.
When a document is versioned several times, the items under a document will be in the multiple versioned documents. And that is a reason Document ID is not shown for the items in the case.
Regular Member
Thank you
Now I understand.
I only image that when document is versioned, content is also versioned simultaneously.
Thank you very much.
well it depends which option user selects during creating a version.
There is no straight forward solution at this point of time for your suggestion.
