When running a report through the web service, allow the result to be downloaded in the same way as fetching an attachment
Current functionality, as of 10.9, requires the output file to be stored on the Integrity server. For a web service, it would make more sense to be able to capture the resulting file with the response to the runreport request, using a multipart stream the same as is used for retrieving attachments. Without this, the web service call requires a location on the server to store the output, and then needs to be able to retrieve from that location in order to make use of the output. That requires a share to be defined to the server, additional permissions,  and can run into naming collisions if not careful.
