While launching Integrity Client- Administration showing the error : Error connecting to ptc-training.ptc.com:7001: The IP address of the host could not be determined.
Newbie
Trying to launch Integrity client - Administration . but showing the error as Error connecting to ptc-training.ptc.com:7001: The IP address of the host could not be determined. as shown in ImageIntegrity error.jpg
Re: While launching Integrity Client- Administration showing the error : Error connecting to ptc-training.ptc.com:7001: The IP address of the host could not be determined.
Clear out your host and port information in preferences and reenter it.  I just close the session and start over.  it happens less frequently if you have your login set up to prompt for host / port and user ID / password.
Can you tell me which values should I provide for Microsoft SQL Server Database as shown belowIntegrityy.jpg
While Installation Integrity Client I have provided values as
Host Name = ptc-training.ptc.com
port = 7001
Try this:
Edit the <installdir>config\properties\is.properties file, and set the "mksis.hostname" property to the machine name
Example: mksis.hostname= ptc-training.ptc.com
Set the local DNS
Go to "C:\Windows\system32\drivers\etc\".
Edit the "hosts" file.
Add the following line:
127.0.0.1                 ptc-training.ptc.com
Restart the machine
Manoj,
Are you still in the process of actually trying to install the Integrity server?  This screenshot is from that, so if so, you're not going to be able to connect using the admin client, until all of this is done?  Your SQL Server DBA should be able to provide you the values for the database (or whoever created the SQL server database being used for this).
Oh I see.  This is likely related to the training course stuff.  Perhaps they have something setup already, for your use.  I'll let one of them chime in, if so.
