Is there a way to delete or deactivate a test step in Integrity 10 on GUI or eith CLI? In Workfloww it has 2 status: unspesified and active, but there is no way from status "active".
the workflow in Integrity is up to you / your administrator to define.
This way you can also define another state, and call it "inactive".
Is this a valid approach for you?
Volker
Volker
Thank you, I'll ask the administrator about it
Istvan.
