displaying project revisions in project view (SI)?
JensN.
Hi all,
in SI ("Configuration Management") you can see in the project view in the column "member revision" the revision number of the members contained in a project. In the helpfile (http://<servername>:<port>/integrity110_hc/index.jspx?id=client_proj_opening_projects.mif-2&action=show) you can read that this column also shows the revision of contained subprojects:
But this is not the case in our system (ILM 11.0.506):
As you can see in the project history, the selected subproject has revisions up to 1.12, but in the column is nothing to see.
I also don't remember that this would have been the case in previous versions of Integrity. I'm asking here if anyone else sees the revision of a subproject in the project view and we have a misconfiguration somewhere in our system?
Thanks, Jens
4 REPLIES 4
awalsh
(To:JensN.)
I think it's a documentation error rather than your system. I haven't see the subproject revision show in a long time.
JensN.
(To:awalsh)
I already was afraid of that, but sometimes I'm not sure if what I'm looking for hasn't been seen somewhere before.
kind regards, Jens
kthierer
11-Garnet
(To:JensN.)
I guess you might have seen that in a build sandbox
or a build project view.
Projects and sub projects do not have a revision but a "current state", unless
a special build resp. checkpoint is referenced.
I guess this is meant with "(if any)" in the documentation.
HTH
  Jürgen
JensN.
(To:kthierer)
Hi Jürgen,
yes, i've seen these numbers in build sandboxes, but i was confused by the sentence in the documentation and i wasn't sure anymore, if i had seen this ever before in normal sandboxes or in the project view.
kind regards, Jens
