enable "custom Buttons" inside dashboards and IPT
It would be very nice, if it was possible to define Custom Action inside a Dashboard of Item presentation template.
Example 1:
You have a Project - Risk Dashboard and you want a button "create new Risk item".
Currently this only works if you do some "dirty hack" utilizing the web-client.
Example 2:
You have e.g. an Requirement and you want a button "Run Item Trace Report" inside the Item's view.
In both cases you have to Switch between Web-Client and Client-GUI to achieve simple Tasks.
1 Comment
Aquamarine
Not the same, but a similar RfC should already exist (RfC: 145373,  Case:10974217). Unfortunately i cannot find this RfC at the PTC-Support-Website.
kind regards, Jens
