extend runchart api to accept issue ids
0 Kudos
Status quo:
- a chart can only be defined to use a named query
- this query can be overruled during the call of "runchart" using either the "--query=..." or "--queryDefinition=.." parameter
Problem:
At least for trend charts (chart type = "field value trend") 95% of the use cases require a single item ID whose field value trend shall be plotted. Currently this requires either a lot of IMHO meaningless named queries or a workaround, using something like
im runchart -g --queryDefinition=(field[ID]=12345678)) myTrendChart
Idea:
extend the runchart api to have an additional, optional  "--issues=...." parameter.
im runchart -g --issues=12345678 myTrendChart
 If the issues parameter is set, it overrules all other query related settings.
