in MKS Source : Transforming a folder in subproject
ptc-6606728
is there a way to do the change from a folder to subproject (a lot of folder have been created by errors they should be subproject).
BR
Lionel
LLawton
(To:mrump)
Just a couple more details to add to Matthias' response:
- I guess step 1.1 is for safety so you have a local backup, since everything can be done from the Project view.
- Step 3 is optional: if you use the "Create Subprojects" option or you set it as a policy as explained before, the subprojects will be created automatically when you add the members. That can save you a lot of work if you have large projects and many nested folders.
10 REPLIES 10
JensN.
(To:ptc-6606728)
I thought all "folders" in source integrity actually are subprojects? How did you create folders which are not subprojects?
kind regards, Jens
mrump
(To:JensN.)
Actually "creating a subproject for each folder" is an option in the "addMember", "AddMembersFromArchive"m "moveMember" and "MoveSubprojects" command.
I'd not recommend to set this option to false, as it limits your options for future use of these folders.
  • You cannot checkpoint or label them individually, as you can do with subprojects.
  • You cannot create specific ACLs, as you can do with subprojects.
  • You cannot share them individually, as you can do with subprojects.
So to avoid any of this, you can "enforce" a true using the Configuration Management global policies in the admingui.
Just add this in the text field on the "Other" tab.
si.AddMembers.createSubprojects=true
si.AddMembers.createSubprojects;locked=true
si.AddMembersFromArchive.createSubprojects=true
si.AddMembersFromArchive.createSubprojects;locked=true
si.MoveMembers.createSubprojects=true
si.MoveMembers.createSubprojects;locked=true
si.MoveSubprojects.createSubprojects=true
si.MoveSubprojects.createSubprojects;locked=true
HTH Matthias
Yes matthias you're right. and you answer to Jens correctly, But not to mine 😉
Policies has already been changed after seeing this problem so we won't have new folders, but is it possible to transform folder in subproject ?
mrump
(To:ptc-6606728)
Sorry Lionel,
seems like I just lost fokus .
Here's what i would try.
1. checkpoint your project
1.1 create a sandbox of you project and resync.
2. open the project in a project view and drop the folders.
3. create the subprojects in question manually in the project view
4. use "add member from archive" to fill the new subprojects individually
finally check your sandbox and resync.
HTH Matthias
LLawton
(To:mrump)
Thanks Laurent and Matthias i'm trying this .
BR
Lionel
Some time ago I came to the idea to generate a batch file for this with following approach:
gen_folder_as_project_batch.bat
set FOLDERNAME=src
si print -R --revision=:member --format="si addmemberfromarchive --cpid=:none --archive \"{archivename}\" --revision={memberrev} --createsubprojects \"{membername}\" & pause \n" --noHeaderFormat --noTrailerFormat --filter=file:"%FOLDERNAME%/*" > "%FOLDERNAME%_ as_project.bat"
Please review yourself.
This example will generate "src_as_project.bat"
Jürgen
KaelLizak
(To:mrump)
This has been captured in CS186912.
(Actually, it's from a case that pre-dates our current KB, but it's effectively the same as Matthias' answer. I expect Lionel will shortly be marking Matthias' answer as correct. )
Kael
Kind Regards,
Kael Lizak
Hello all,
I have almost done as mathias describe, just I have not dropped the folders in 2 but at the end.
So after having create subprojects, I can add non members drom sandbox menu, and then delete the folders.
After that I have to delete entirely my sand box and recreate a new one because file seemed lost.
But they were effectively here.
So thank you for your help.
BR
Lionel
KaelLizak
(To:ptc-6606728)
Hello Lionel,
To let everyone know what what helped you resolve this issue, please click theCorrect Image button on Mattias' answer.
Doing this lets anyone else looking for this information see the answer you chose to solve your problem.
Kael
Kind Regards,
Kael Lizak
