"Copy Common Fields" option when creating related items from test results
This is a product idea conversion of case 12444712 and RFC 1031765 from March of 2015.
Some test cases will be stored in a centrally controlled area. Multiple projects will be executing the test case in their respective test sessions. The test sessions will contain attributes important to future change orders (change requests/defects). When a test case fails, we want the new change order to inherit the project and other common fields from the executed test session.
Test Case: Turn on the machine
  • 100 Projects execute this test case.
  • The test case fails for Project 99
    • Change order is submitted through the test results editor
  • The change order should be logged against project 99 with common fields copied to the newly created item.
1 Comment
Alexandrite
    I was reviewing your Idea and I think this is a good candidate for Future Consideration. Please do note that it will not be on our immediate list of items as our next step is the UI Replacement Project.
Kartik Oak
