I want to create a custom report with requirement ID, tests ID, tests name, result, and few editable fields.
Could you please suggest is there any way to do in Integrity report. I'm using Integrity 11
Thanks and Regards,
Shilpa
Hello Shilpa,
I would be interested in helping you with this report.
There are some questions, please allow me to ask them beforehand:
Here are some comments that you should consider for the implementation:
Please be as specific as possible with your answers.
Perhaps we should organize a Web Session, this might help better, let me know if you are interested.
Volker
Hello Volker,
Many thanks for your response.
Please find below answers to your question:
Web session would be very helpful if possible.
Many thanks and Regards,
Shilpa
Hello Shilpa,
in addition to my emails I would like to respond here as well, also for others who are interested in this topic.
a) if possible, use the Build-in Test Result Editor from Integrity
b) Offline Test Result editing is very often requested, and we have implemented an Offline Excel solution which allows customers to enter Test Case and Test Step results and send them back into Integrity when again online.
c) Adding the Requirement Details to Test Result entry forms is not that common, but makes sense especially when you plan to perform a QS action.
d) further more we have implemented different kinds of reports, in html, Word, Excel .... to serve as Test State Reports. They are usually customer specific, although the way how we retrieve data from Integrity is highly standardized.
e) Also ThingWorx could be used to become a front end for Testers, in case there is a need for Web based Test Result entry.
Adding an example of the Excel Offline Template ...
Any follow up question is welcome.
Regards
Volker
