If there is a requirement 1.1.1 which has some comment inside a field, can we create an additional requirement 1.1.1.1 to that in the xml mapping file?
Something like the attachment... Here 3.13.1 is a requirement with some value, now can I create additional requirement to that 3.13.1.1. Is this possible? How can this be achieved?
Hello Karthik,
I don't have the background with RIF to be able to address your question, and it seems I'm not alone. Have you opened a case with PTC Integrity Support?
Kael
Hello Karthik,
Kael
Hi Kael,
I actually came up with a workaround for the above issue. Instead of doing this on the xml mapping file, I opted for a trigger in Integrity to create a new requirement when conditions are met. This way i would customisation/configuration changes that would be needed only on the Integrity side.
I have not created a ticket for this, but if required in future I will get back to PTC Integrity support.
Thanks for getting back to me.
Kind Regards,
Karthik
