Hello friends,
I am trying to create a Custom Recipe in PTC Integrity 10.9 for a report where I need to fetch the field value of a document that is related to the document that has been passed as an input to the report.
var fieldvalue1 = <%fieldname1%>;
var fieldvalue2 = <%fieldname2%>;
Here, I want the fieldvalue2 to be value of the field "fieldname2"as per the document that I got as "fieldvalue1".
I am very new to Integrity custom report creation. Appreciate your help.
To specify a relationship field rather than the item field, you need to use <%Relationship fieldname2%>, within the <%beginrelationshipdetail relationshipname%> section of the report.
There are some example report recipes using relationships (e.g. Detail - HTML, Row, Relationships). If you create a report using the recipe, then view the report on the CLI using im viewreport reportname, you can see how the field values are defined. Here's a sample relationship section of a report created from the Detail - HTML, Row, Relationships recipe:
<!-- Relationships info --> <tr class="odd_row"> <td colspan="4" class="border"> <span class="bold_color_underline">Documented By:</span><br> <div class="center"> <table class="list"> <%beginrelationshipsdetail Documented By%> <%relationshipsortby ID+%> <!-- Display relationship issue field headings --> <%beginrelationshipsection header%> <tr> <th>ID</th> <th>Type</th> <th>State</th> <th>Document Short Title</th> </tr> <%endrelationshipsection%> <!-- Display no relationships found --> <%beginrelationshipsection none%> <tr><td>No related items.</td></tr> <%endrelationshipsection%> <!-- Display relationship issue field values --> <tr> <td><%Relationship ID%></td> <td><%Relationship Type%></td> <td><%Relationship State%></td> <td><%Relationship Document Short Title%></td> </tr> <%endrelationshipsdetail%> </table> </div> </td> </tr>
