Having an issue with Project which contains parentheses and cli
rlyvers
So I have a project which has parenthesis in it, and I am trying to execute a query from the command line constructed from a query definition.
Here is a Query defined which  has the same query definition:
Query Definition: ((field["Summary"] contains "#29") and (field["Type"] = "Sprint") and (field["Project"] = "/Electronic Tools (ETPL)/Foobar"))
Sorted By: ID (Ascending)
Fields: ID,Type,Summary,State,Assigned User,Project
Here is the issue I receive when I enter the query defined for the issues cli interface.
im issues --queryDefinition="((field[Summary] contains ""#29"") and (field[Type] = ""Sprint"") and (field[Project] = ""/Electronic Tools (ETPL)/Foobar""))"
*** MKS124814: Cannot show view information: A "(" was found within a ( ) group. Error occured before "ETPL)/Guidanz))"
I have tried escaping the parentheses with a backquote (`), and this did not help the situation. Can I just not have a parentheses in the name?
1 ACCEPTED SOLUTION
awalsh
(To:rlyvers)
The trick is to use single quotes around the entire query definition and double quotes for the field names and values.  For example:
im issues --queryDefinition='((field[Type]="Work Item") and (field[Project]="/My (Test) Project"))'
This is also documented in article 171843.
awalsh
(To:rlyvers)
