How to get constraints(allowed values) of the type/field
MartinBeisser
3-Visitor
We have some constraints on basic/field relationsips e.g. of the field "category".
We want the get the allowed values of this field via api/commandline.
What we must do?
Thanks in advance
You can view the field relationships with "im viewtype" on either command line or API.
The following is the Field Relationship section of "im viewtype" for a sample Requirement type:
CLI:
Field Relationships:
Referenced Item Type=Requirement Specification Document:Category=Document
Referenced Item Type=Shared Requirement:Category=Technical Requirement,System Requirement,Component Requirement,Heading,Business Requirement,Comment,User Requirement,Functional Requirement,Non-Functional Requirement,SRS (Software Requirement),SSS (System/Subsystem Requirement),IRS (Interface Requirement)
constraintrule=(((field["Category"] = "Non-Functional Requirement") or (field["Category"] = "Functional Requirement")) and (field["State"] = "Cancelled")):Additional Comments=:all,mandatory,description=test rule
API:
      <Field name="fieldRelationships">
        <List elementType="item">
          <Item id="Referenced Item Type" modelType="im.Field" displayId="Referenced Item Type">
            <Field name="targetFields">
                <Item id="Category" modelType="im.Field" displayId="Category">
                  <Field name="sourceValues">
                    <List>
                      <Value dataType="string">Requirement Specification Document</Value>
                    </List>
                  </Field>
                  <Field name="targetValues">
                    <List>
                      <Value dataType="string">Document</Value>
                    </List>
                  </Field>
                  <Field name="targetValueType">
                    <Value dataType="string">static</Value>
                  </Field>
                  <Field name="mandatory">
                    <Value dataType="boolean">false</Value>
                  </Field>
                  <Field name="errMandatory">
                    <Value></Value>
                  </Field>
                  <Field name="errInvalidated">
                    <Value></Value>
                  </Field>
                  <Field name="description">
                    <Value></Value>
                  </Field>
                  <Field name="cliSpec">
                    <Value dataType="string">Referenced Item Type=Requirement Specification Document:Category=Document</Value>
                  </Field>
                  <Field name="all">
                  </Field>
                </Item>
                    <List>
                      <Value dataType="string">Shared Requirement</Value>
                    </List>
                  </Field>
                    <List>
                      <Value dataType="string">Technical Requirement</Value>
                      <Value dataType="string">System Requirement</Value>
                      <Value dataType="string">Component Requirement</Value>
                      <Value dataType="string">Heading</Value>
                      <Value dataType="string">Business Requirement</Value>
                      <Value dataType="string">Comment</Value>
                      <Value dataType="string">User Requirement</Value>
                      <Value dataType="string">Functional Requirement</Value>
                      <Value dataType="string">Non-Functional Requirement</Value>
                      <Value dataType="string">SRS (Software Requirement)</Value>
                      <Value dataType="string">SSS (System/Subsystem Requirement)</Value>
                      <Value dataType="string">IRS (Interface Requirement)</Value>
                    </List>
                  </Field>
                  </Field>
                  </Field>
                    <Value></Value>
                  </Field>
                    <Value></Value>
                  </Field>
                    <Value></Value>
                  </Field>
                    <Value dataType="string">Referenced Item Type=Shared Requirement:Category=Technical Requirement,System Requirement,Component Requirement,Heading,Business Requirement,Comment,User Requirement,Functional Requirement,Non-Functional Requirement,SRS (Software Requirement),SSS (System/Subsystem Requirement),IRS (Interface Requirement)</Value>
                  </Field>
                  <Field name="all">
                  </Field>
                </Item>
              </List>
            </Field>
          </Item>
          <Item id="constraintrule=(((field[&quot;Category&quot;] = &quot;Non-Functional Requirement&quot;) or (field[&quot;Category&quot;] = &quot;Functional Requirement&quot;)) and (field[&quot;State&quot;] = &quot;Cancelled&quot;)):Additional Comments=:all,mandatory,description=test rule" modelType="ConstraintRule" displayId="constraintrule=(((field[&quot;Category&quot;] = &quot;Non-Functional Requirement&quot;) or (field[&quot;Category&quot;] = &quot;Functional Requirement&quot;)) and (field[&quot;State&quot;] = &quot;Cancelled&quot;)):Additional Comments=:all,mandatory,description=test rule">
            <Field name="targetField">
              <Item id="Additional Comments" modelType="im.Field" displayId="Additional Comments">
              </Item>
            </Field>
            <Field name="rule">
              <Value dataType="string">(((field["Category"] = "Non-Functional Requirement") or (field["Category"] = "Functional Requirement")) and (field["State"] = "Cancelled"))</Value>
            </Field>
              <Value dataType="boolean">true</Value>
            </Field>
              <Value></Value>
            </Field>
              <Value></Value>
            </Field>
              <Value dataType="string">test rule</Value>
            </Field>
              <Value dataType="string">constraintrule=(((field["Category"] = "Non-Functional Requirement") or (field["Category"] = "Functional Requirement")) and (field["State"] = "Cancelled")):Additional Comments=:all,mandatory,description=test rule</Value>
            </Field>
            <Field name="all">
            </Field>
              <Value></Value>
            </Field>
            </Field>
          </Item>
        </List>
      </Field>
You can also see all values for the Category with "im viewfield --overrideForType="[shared item type]" "Shared Category". im viewfield and im viewtype are both published API commands.
