We need to find the author of drop member operations using CLI.
We tried to use "si mods" but the result shows the members and I get the CPs but I cannot match the dropped member with the CP used for the drop operation on that member.
>si mods --fields=change,name --showMemberChanges --showAttrChanges --showChangePackages --project=/xxx/yyy/project.pj --yes
We also tried:
>si viewsandbox --includeDropped --sandbox=d:\test_xxx\project.pj
But the result does not show me the author.
Any hints on this?
Thank you
Cristina
Hello Cristina,
we have the same problem an i have found a way to find out the user who dropped the member:
From GUI:
Use "ChangePackage"->"Find"
Member type=member
Project=yourProject
Member=membername
Entry type=drop
Here you can find the ChangePackage which was used for the Drop-Command and also the user who created/used the ChangePackage.
From CMD:
si viewcps --filter=member:"membername" --filter=type:drop --filter=project:"yourprojectpath" --filter=membertype:member
This way works...but it would be nice if there is a more easier way to get the information for dropped members/subprojects.
Hello Cristina,
From GUI:
Member type=member
Project=yourProject
Member=membername
Entry type=drop
From CMD:
Hello Tobias,
This is what I needed, the CLI command 🙂
Thanks very much for it.
You are right, it should be an easier way to get these information. But I don't think PTC will make this case a priority 😞
Thank you again for your help.
Cristina
