How to pass the parameter in Walk Query Section?
Level 10
Hi Everyone,
Urgent help required on this :-
Any help would be appreciable.
Vielen Dank,
Kapil Jain
Re: How to pass the parameter in Walk Query Section?
Could you clarify what issue you are having?  What are you running (exact code) and what errors are you getting?
It looks like the solution for that post was that the variable could not be used in the tag. That answer hasn't changed as far as I know.
Hi @awalsh,
Thanks for your response.
Actually i am creating a Report recipe and using this tag:-
<%begindetail%>
<%beginrelationshipsdetail Query[(walkdocordered[<%<%DocumentID%>%>]recurseinclude)]%>
And DocumentID is a variable or you can say like this:-
var DocumentID = 1234;
<%begindetail%>
But i am not getting fruitful result. Please take a look over the complete code:-
<script type="text/javascript">
function documentdata(DocumentID)
alert(DocumentID);
var content='<div class="section_heading">Document Content</div>' +
'<table width="100%" style="background: #dbe7f9;" class="section1" cellspacing="0" cellpadding="3" border="1">' +
'<tr class="result_header">' +
'<th align="center" class="field_headings">Category</th>' +
'<th align="center" class="field_headings">State</th>' +
'<th align="center" class="field_headings">Text</th>' +
'<th align="center" class="field_headings">Trace Status</th>' +
'<th align="center" class="field_headings">ID</th></tr>';
<%begindetail%>
content +='<td class="field_headings" align="center"><%Relationship Category%></td>' +
'<td class="field_headings" align="center"><%Relationship State%></td>' +
'<td class="field_headings"><%Relationship Text%></td>' +
'<td class="field_headings" align="center"><%Relationship Trace Status%></td>' +
'<td align="center" class="field_headings"><a href="integrity://BLRMIESPC-1233.lnties.com:7001/im/viewissue?selection=<%Relationship ID%>" target="_blank"><%Relationship ID%></a></td></tr>';
<%endrelationshipsdetail%>
<%enddetail%>
content += '</table></br>';
document.getElementById("demo").innerHTML =content;
</script>
Giving some Errors like Unexpected Token and function documentdata is not defined.
Looking forward to hear from you.
Vielen Dank,
Kapil Jain
Hi @awalsh,
Any response from your side because if you can help me to solve this then i can move ahead with the idea i have ?
Vielen Dank,
Kapil Jain
I'm sorry Kapil, I don't have any ideas on this one. I don't think it's possible.
