ILM11 - CM where used
md'ambrosio
8-Gravel
Hi all,
Integrity 11.1 Configuration Management.
Is there a way to find the list of all the CM projects where a member is contained ?
I need to search for file name (e.g. Frontload.sql) and get the list of all the CM projects where the member is contained.
Many thanks Martina
1 ACCEPTED SOLUTION
The Locate command will give you this information.  From the Member menu, select Locate By Name...
Type in the file name and click ok.
By default, it will return all current project configurations where the file is a member.  If you want to include previous checkpoints, change the "Depth to Lookup" option to "Current and Checkpointed".
If Locate By Name... is not in the Member menu, then you will need to customize your viewset to add this menu item.
