Can someone provide an example of the 'im editfield' command that sets the set of a pick field from active to inactive?
I have tried the following, and a few variations, without success.:
im editfield --picks="value=9,Inactive" "my test field"
Our ultimate intent is coding this in a script. So an example in JavaScript that's invoked by a manual trigger would be even better.
-Sean
Hi Sean,
you can set pick fields to active, if you list them in your command.
The other way round: pick fields are set to inactive, if you don't list them.
E.g.: Field "my test field" with pick values "green" (0), "yellow" (1) and "red" (2)
The command
im edit field --picks=green:0:none,red:2:none "my test field"
sets the picks "green" and "red" to active, and sets "yellow" to inactive.
The syntax for the --picks-option is: <text>:<value>:<image>,...
Hi Sean,
The command
Hi Markus,
Thanks for the information. I'll give that a try.
-Sean
