createsandbox - development path and project options are mutually exclusive with new project syntax
SOLVED
Level 4
Creation of build sandbox with a checkpoint revision using the following syntax fails with a message stating that "development path and project options are mutually exclusive with new project syntax"
si createsandbox -P<project path> -projectRevision=1.43
Integrity Client version is 11
The command works fine without the projectRevision option.
What is the new syntax for specifying checkpoint version ?
Satish K
Re: createsandbox - development path and project options are mutually exclusive with new project syn
Hi Satish,
What syntax did you use for the project path? The commands accept two different project formats:
Flat Path: /Test/project.pj
Config Path: #/Test   <-- begins with a # sign
Config Paths can already include variants and build numbers.
For example the config path syntax of:
si viewproject -P #/Test#d=MyDev
is equivalent to Flat path syntax:
si viewproject -P /Test/project.pj  --devPath=MyDev
Making the following an invalid command:
si viewproject -P #/Test#d=MyDev --projectRevision=1.1.1.1
*** The development path and build projects options are mutually exclusive with new project syntaxes. Specify one or the other,
In other words, using a configpath syntax in your -P parameter will throw the error if you also try to use --devPath or --projectRevision.
Hope this helps!
Hi Satish,
Hope this helps!
Also, the syntax for giving a project revision (build) in the configuration path is #b=[rev] or #b=[label], where [rev] is the project revision and [label] is a label on the project revision.
e.g. #/MyProject#sub/sub2#b=1.34
