MQTT Egress – Private Preview in ThingWorx 10.1
No ratings
Introduction
With ThingWorx 10.1, we're excited to announce MQTT support for IoT streams for data egress as Private Preview. This is a significant value add that allows ThingWorx to continue to be used as a DataOps layer for end-to-end industrial data management. With its ability to ingest data from disparate sources, contextualize and transform it, and send data in a custom-defined format over Kafka, and now MQTT, ThingWorx enables real-time consumption of data by end applications, allowing necessary interoperability without the worry of data lock-in.
Especially in the age of AI, customers can use ThingWorx not only to ingest data from connected machines, systems, and people but also to push processed, contextualized, AI-ready data outward. This enables external systems, data lakes, cloud systems, or UNS layers to consume the data in real time, making IT/OT convergence seamless.
With this capability, having a Sparkplug B connector built in, users can use ThingWorx to directly load contextualized data onto MQTT brokers that is transformed into Sparkplug B format, helping them achieve their goals for establishing a decoupled, modular, and modern manufacturing architecture allowing complete access and traceability of their own data.
Modern Manufacturing ArchitectureModern Manufacturing Architecture
Built for Reliability and Scale
MQTT (Message Queuing Telemetry Transport) is a lightweight, publish-subscribe protocol designed for IoT efficiency. The ThingWorx 10.1 implementation uses the Durable Queue Framework, the same foundation behind IoT Streams, to ensure reliable message delivery even under network fluctuations.
Developers can configure MQTTQueueProviders to define topics and manage data publishing with minimal setup. Each queue can dynamically format its topic names, ensuring scalable routing for multiple devices or templates. The system supports both MQTT 3.1.1 and 5.0 for broad compatibility.
Seamless Setup, Strong Integration
New ThingWorx entities such as SparkplugBQueueProvider, SparkplugBDevice ThingShape, and related services simplify setup and connection management. Administrators can create and associate IoT Streams with MQTT queues in a few clicks, route property updates to external topics, and monitor connection health directly within Composer.
This unified workflow makes it easy to connect ThingWorx data to external analytics systems, industrial data lakes, or cloud-based applications using low-code tools from ThingWorx.
Adding Structure with Sparkplug B
Beyond raw MQTT data, ThingWorx now supports Sparkplug B, an open industrial data specification that brings structure and state awareness to MQTT communications. Sparkplug B defines a common topic format and uses birth and death messages to indicate device lifecycle events, ensuring that systems always know which devices are online or offline. Payloads are serialized using Protocol Buffers (Protobuf) for lightweight, high-performance communication, making it ideal for bandwidth-constrained environments.
Together, these enhancements position ThingWorx as both a data receiver and publisher, a core participant in UNS-aligned ecosystems where structured MQTT data flows freely across IT and OT systems, simplifying IT/OT convergence.
Feature Summary
Capability
Description
MQTT Publishing
Send Thing property data to brokers like HiveMQ or Mosquitto.
Sparkplug B Support
Structured MQTT with standardized topics and lifecycle management.
Durable Queue Integration
Ensures reliable, ordered message delivery.
New Queue Providers
MQTTQueueProvider and SparkplugBQueueProvider for outbound data.
Unified Namespace Alignment
Enables ThingWorx to act as a UNS-compliant data source.
Join the Private Preview
The MQTT Egress capability extends ThingWorx interoperability beyond ingestion, allowing contextualized data to be shared across the enterprise or to the cloud. You can now join the Private Preview to gain early access to this key building block of the future UNS-enabled ThingWorx ecosystem and contribute feedback that helps shape its evolution.
To understand what Private Preview means in ThingWorx, check this overview here
Vineet Khokhar
Principal Product Manager, IoT Security
Stay tuned for more updates as we approach the release of ThingWorx 10.1, and as always, in case of issues, feel free to reach out to <support.ptc.com>
Version history
Last update:
‎Dec 19, 2025 10:54 AM
Updated by:
Contributors
