Home Voice Assistant ( An Voice Assistant for Smart Connected Home )
lnarasimhankp
3-Newcomer
HOME VOICE ASSISTANT is a voice based cloud application.
It is based on the SIRI / CORTANA speech recognition software. It understands command, questions and emotions from the user and respond/reply with appropriate actions.
Home Voice Assistant is managed by a web/mobile app. The app will monitor/control the usage of the Home Assistant. It helps to modify/reset the commands. It helps to activate / deactive Home Voice Assistant.
2 REPLIES 2
ocarvatchi
11-Garnet
Hello Lakshmi, thank you for sharing this! Using thermal heat signature sensors to activate the application is a unique approach. Great work!
lnarasimhankp
3-Newcomer
Hi Oana,
Thanks for your feedback
