8.4 Microsoft SQL Azure and MS SQL Highlights
Opal
Why?
  • Reduce or eliminate hardware costs
  • Get database portability across on-premise and cloud compatible virtualization
  • High speed and minimum downtime
  • Optimize performance
Three deployment options:
  • Single: best for apps requiring resource guarantee at database level
  • Elastic pool: SAAS apps with multiple databases achieving better cost efficiency
  • Managed instance: best for modernization at scale
MS SQL Improvements:
  • Ingest millions of data items/day with imrpoved MS SQL
  • 150% improvement  ingestion throughput with MS SQL persistence provider
  • Optimized indexing to achieve better peformance for the same compute at the same price
ThingWorx with Microsoft database solution:
  • Azure SQL logical server (single instance and elastic pool) v12
  • Azure SQL managed server v12
  • MS SQL sever 2016
  • Azure PostgreSQL 9.6 and 10
Q: What is the rate as compared to PostgreSQL?
A: We are in process launching new sizing guide that will be out in a few weeks. MS SQL is around 15-22K writes per sec. Comparable to Postgres.
