ActiveMQ Java Sample Consumer
Marble
Shown below is example code that when deployed in the appropriate container, will allow an end-user to talk to the Axeda Platform Integration Queue.
A customer should supply their unique values for the following properties:
  • queueName
  • user
  • password
  • url
import java.util.Properties;
import javax.jms.*;
import javax.naming.*;
public class SampleConsumer {
    private String queueName = "com.axeda.integration.ACME.queue";
    private String user = "system";
    private String password = "manager";
//private String url = "ssl://hostname:61616";
  private String url = "tcp://hostname:61616";
    private boolean transacted;
    private boolean isRunning = false;
    public static void main(String[] args) throws NamingException, JMSException
        SampleConsumer consumer = new SampleConsumer();
        consumer.run();
    public SampleConsumer()
        /** For SSL connections only, add the following: **/
//        System.setProperty("javax.net.ssl.keyStore", "path/to/client.ks");
//        System.setProperty("javax.net.ssl.keyStorePassword", "password");
//        System.setProperty("javax.net.ssl.trustStore", "path/to/client.ts");
    public void run() throws NamingException, JMSException
        isRunning = true;
        //JNDI properties
        Properties props = new Properties();
        props.setProperty(Context.INITIAL_CONTEXT_FACTORY, "org.apache.activemq.jndi.ActiveMQInitialContextFactory");
        props.setProperty(Context.PROVIDER_URL, url);
        //specify queue propertyname as queue.jndiname
        props.setProperty("queue.slQueue", queueName);
        javax.naming.Context ctx = new InitialContext(props);
        ConnectionFactory connectionFactory = (ConnectionFactory)ctx.lookup("ConnectionFactory");
        Connection connection = connectionFactory.createConnection(user, password);
        connection.start();
        Session session = connection.createSession(transacted, Session.AUTO_ACKNOWLEDGE);
        Destination destination = (Destination)ctx.lookup("slQueue");
        //Using Message selector ObjectClass = ‘AlarmImpl’
        MessageConsumer consumer = session.createConsumer(destination, "ObjectClass= 'LinkedList'");
        while (isRunning)
            System.out.println("Waiting for message...");
            Message message = consumer.receive(1000);
            if (message != null && message instanceof TextMessage) {
                TextMessage txtMsg = (TextMessage)message;
                System.out.println("Received: " + txtMsg.getText());
        System.out.println("Closing connection");
        consumer.close();
        session.close();
        connection.close();
Tags (2)
