Shown below is example code that when deployed in the appropriate container, will allow an end-user to talk to the Axeda Platform Integration Queue.
A customer should supply their unique values for the following properties:
import java.util.Properties;
import javax.jms.*;
import javax.naming.*;
public class SampleConsumer {
private String queueName = "com.axeda.integration.ACME.queue";
private String user = "system";
private String password = "manager";
//private String url = "ssl://hostname:61616";
private String url = "tcp://hostname:61616";
private boolean transacted;
private boolean isRunning = false;
public static void main(String[] args) throws NamingException, JMSException
SampleConsumer consumer = new SampleConsumer();
consumer.run();
public SampleConsumer()
/** For SSL connections only, add the following: **/
// System.setProperty("javax.net.ssl.keyStore", "path/to/client.ks");
// System.setProperty("javax.net.ssl.keyStorePassword", "password");
// System.setProperty("javax.net.ssl.trustStore", "path/to/client.ts");
public void run() throws NamingException, JMSException
isRunning = true;
//JNDI properties
Properties props = new Properties();
props.setProperty(Context.INITIAL_CONTEXT_FACTORY, "org.apache.activemq.jndi.ActiveMQInitialContextFactory");
props.setProperty(Context.PROVIDER_URL, url);
//specify queue propertyname as queue.jndiname
props.setProperty("queue.slQueue", queueName);
javax.naming.Context ctx = new InitialContext(props);
ConnectionFactory connectionFactory = (ConnectionFactory)ctx.lookup("ConnectionFactory");
Connection connection = connectionFactory.createConnection(user, password);
connection.start();
Session session = connection.createSession(transacted, Session.AUTO_ACKNOWLEDGE);
Destination destination = (Destination)ctx.lookup("slQueue");
//Using Message selector ObjectClass = ‘AlarmImpl’
MessageConsumer consumer = session.createConsumer(destination, "ObjectClass= 'LinkedList'");
while (isRunning)
System.out.println("Waiting for message...");
Message message = consumer.receive(1000);
if (message != null && message instanceof TextMessage) {
TextMessage txtMsg = (TextMessage)message;
System.out.println("Received: " + txtMsg.getText());
System.out.println("Closing connection");
consumer.close();
session.close();
connection.close();
