All Data Items to XML
Garnet
This script finds all the data items both current and historical on all the assets of a model and outputs them as XML.
Parameters:
  1. model_name
  2. from_time
  3. to_time
import com.axeda.drm.sdk.Context
import com.axeda.drm.sdk.device.ModelFinder
import com.axeda.drm.sdk.device.DeviceFinder
import com.axeda.drm.sdk.data.CurrentDataFinder
import com.axeda.drm.sdk.data.HistoricalDataFinder
import groovy.xml.MarkupBuilder
* AllDataItems2XML.groovy
* Find all the historical and current data items for all assets in a given model.
* @param model_name        -   (REQ):Str name of the model.
* @param from_time         -   (REQ):Long millisecond timestamp to begin query from.
* @param to_time           -   (REQ):Long millisecond timestamp to end query at.
* @note from_time and to_time should be provided because it limits the query size.
* @author Sara Streeter <sstreeter@axeda.com>
def response = [:]
def writer = new StringWriter()
def xml = new MarkupBuilder(writer)
// measure the script run time
def timeProfiles = [:]
def scriptStartTime = new Date()
try {
// getUserContext is supported as of release 6.1.5 and higher
    final def CONTEXT = Context.getUserContext()
// confirm that required parameters have been provided
    validateParameters(actual: parameters, expected: ["model_name", "from_time", "to_time"])
// find the model
    def modelFinder = new ModelFinder(CONTEXT)
    modelFinder.setName(parameters.model_name)
    Model model = modelFinder.findOne()
// throw exception if no model found
    if (!model) {
        throw new Exception("No model found for ${parameters.model_name}.")
// find all assets of that model
    def assetFinder = new DeviceFinder(CONTEXT)
    assetFinder.setModel(model)
    def assets = assetFinder.findAll()
// find the current and historical data values for each asset
//note: since device will be set on the datafinders going forward, a dummy device is set on instantiation which is not actually stored
    def currentDataFinder = new CurrentDataFinder(CONTEXT, new Device(CONTEXT, "placeholder", model))
    def historicalDataFinder = new HistoricalDataFinder(CONTEXT, new Device(CONTEXT, "placeholder", model))
    historicalDataFinder.startDate = new Date(parameters.from_time as Long)
    historicalDataFinder.endDate = new Date(parameters.to_time as Long)
// assemble the response
    xml.Response(){
        assets.each { Device asset ->
            currentDataFinder.device = asset
            def currentValueList = currentDataFinder.find()
            historicalDataFinder.device = asset
            def valueList = historicalDataFinder.find()
            Asset(){
                    id(asset.id.value)
                    name( asset.name)
                    serial_number(asset.serialNumber)
                    model_id( asset.model.id.value)
                    model_name(asset.model.name)
                    current_data(){
                        currentValueList.each{ data ->
                        timestamp( data?.getTimestamp()?.format("yyyyMMdd HH:mm"))
                         name(data?.dataItem?.name)
                         value( data?.asString())
                    historical_data(){
                        valueList.each { data ->
} catch (def ex) {
      xml.Response() {
    Fault {
          Code('Groovy Exception')
          Message(ex.getMessage())
          StringWriter sw = new StringWriter();
          PrintWriter pw = new PrintWriter(sw);
          ex.printStackTrace(pw);
          Detail(sw.toString())
return ['Content-Type': 'text/xml', 'Content': writer.toString()]
private Map createTimeProfile(String label, Date startTime, Date endTime) {
            (label): [
                    startTime: [timestamp: startTime.time, readable: startTime.toString()],
                    endTime: [timestamp: endTime.time, readable: endTime.toString()],
                    profile: [
                            elapsed_millis: endTime.time - startTime.time,
                            elapsed_secs: (endTime.time - startTime.time) / 1000
private validateParameters(Map args) {
    if (!args.containsKey("actual")) {
        throw new Exception("validateParameters(args) requires 'actual' key.")
    if (!args.containsKey("expected")) {
        throw new Exception("validateParameters(args) requires 'expected' key.")
    def config = [
            require_username: false
    Map actualParameters = args.actual.clone() as Map
    List expectedParameters = args.expected
    config.each { key, value ->
        if (args.options?.containsKey(key)) {
            config[key] = args.options[key]
    if (!config.require_username) { actualParameters.remove("username") }
    expectedParameters.each { paramName ->
        if (!actualParameters.containsKey(paramName) || !actualParameters[paramName]) {
            throw new IllegalArgumentException(
                    "Parameter '${paramName}' was not found in the query; '${paramName}' is a reqd. parameter.")
Sample Output:
<Response>
  <Asset>
  <id>2864</id>
  <name>keg24</name>
  <serial_number>keg24</serial_number>
  <model_id>1081</model_id>
  <model_name>Kegerator</model_name>
  <current_data>
  <timestamp>20111103 14:44</timestamp>
  <name>currKegPercentage</name>
  <value>34.0</value>
  <timestamp>20111103 14:38</timestamp>
  <name>currTempF</name>
  <value>43.0</value>
  </current_data>
  <historical_data />
  </Asset>
  <Asset>
  <id>2861</id>
  <name>keg28</name>
  <serial_number>keg28</serial_number>
  <current_data>
  <timestamp />
  <value>?</value>
  <timestamp>20111103 14:21</timestamp>
  <value>43.0</value>
  </current_data>
  <historical_data />
  </Asset>
  <Asset>
  <id>2863</id>
  <name>keg21</name>
  <serial_number>keg21</serial_number>
  <current_data>
  <timestamp />
  <value>?</value>
  <timestamp>20111103 14:39</timestamp>
  <value>42.0</value>
  </current_data>
  <historical_data />
  </Asset>
  <Asset>
  <id>2862</id>
  <name>keg25</name>
  <serial_number>keg25</serial_number>
  <current_data>
  <timestamp>20111103 14:36</timestamp>
  <value>34.0</value>
  <timestamp />
  <value>?</value>
  </current_data>
  <historical_data />
  </Asset>
  <Asset>
  <id>2867</id>
  <name>keg29</name>
  <serial_number>keg29</serial_number>
  <current_data>
  <timestamp>20111103 14:48</timestamp>
  <value>35.0</value>
  <timestamp />
  <value>?</value>
  </current_data>
  <historical_data />
  </Asset>
  <Asset>
  <id>2865</id>
  <name>keg27</name>
  <serial_number>keg27</serial_number>
  <current_data>
  <value>34.0</value>
  <value>42.0</value>
  </current_data>
  <historical_data />
  </Asset>
  <Asset>
  <id>2866</id>
  <name>keg23</name>
  <serial_number>keg23</serial_number>
  <current_data>
  <timestamp>20111103 14:46</timestamp>
  <value>34.0</value>
  <timestamp />
  <value>?</value>
  </current_data>
  <historical_data />
  </Asset>
</Response>
Tags (1)
