To help explain some of the different ways in which a prediction can be triggered from a Thingworx Analytics Model, I've built a mashup which allows you to easily trigger these types of prediction:
- API Realtime Prediction
- Analytics Manager: Event
- API Batch Prediction
For information on setting up this environment to use the mashup with some sample data, please see the attached instructions document: Prediction-Methods-Mashup.pdf. The referenced resource files can be found inside resources.zip
For more information on prediction scoring please see this related post: How to score new data with ThingWorx Analytics 8.3.x
Here's an updated version of the Prediction Methods Mashup. The documentation (only) has been updated with simplified steps in Analytics Manager.
In case you get this error message ...
[message: Execution error in service script [PredictStrength] :: TypeError: Cannot call method "RealtimeScore" of null (PredictStrength#29)
... it could be that the Thing representing the Prediction Microservice in your system has a different name to mine (which is AnalyticsServer_PredictionThing). To fix this you can try changing the script Things["ConcreteHelper"].PredictStrength to the attached code.
