Axeda: Get Model Or Asset Alarms and Details
No ratings
This script dumps all the alarms for a model or asset to JSON.
Parameters (one or the other must be provided):
  1. modelName - (OPTIONAL) String - name of the model
  2. assetId - (OPTIONAL) String - id of the asset
import com.axeda.common.sdk.id.Identifier
import com.axeda.drm.sdk.Context
import com.axeda.drm.sdk.audit.AuditCategory
import com.axeda.drm.sdk.audit.AuditMessage
import com.axeda.drm.sdk.scripto.Request
import groovy.json.*
import net.sf.json.JSONObject
import java.net.URLDecoder
import static com.axeda.sdk.v2.dsl.Bridges.*
import com.axeda.services.v2.CustomObjectCriteria
import com.axeda.services.v2.CustomObjectType
import com.axeda.services.v2.ExecutionResult
import com.axeda.services.v2.ExtendedMap
import com.axeda.drm.sdk.device.Model
import com.axeda.drm.sdk.device.ModelFinder
import com.axeda.drm.sdk.device.DeviceFinder
import com.axeda.services.v2.ModelCriteria
import com.axeda.services.v2.ModelType
import com.axeda.services.v2.FindModelResult
import com.axeda.services.v2.AssetCriteria
import com.axeda.services.v2.FindAssetResult
import com.axeda.services.v2.AlarmCriteria
import com.axeda.sdk.v2.bridge.MobileLocationBridge
import com.axeda.drm.sdk.mobilelocation.MobileLocationFinder
import com.axeda.drm.sdk.mobilelocation.CurrentMobileLocationFinder
import com.axeda.drm.sdk.data.AlarmState
import com.axeda.drm.sdk.data.AlarmFinder
import com.axeda.platform.sdk.v1.services.ServiceFactory
import com.axeda.drm.sdk.data.CurrentDataFinder
import com.axeda.drm.sdk.device.DataItem
import com.axeda.drm.sdk.data.HistoricalDataFinder
import com.axeda.drm.sdk.data.DataValue
import com.axeda.drm.sdk.data.DataValueList
import com.axeda.platform.sdk.v1.services.extobject.ExtendedObjectSearchCriteria
import com.axeda.common.date.DateRange
import com.axeda.common.date.ExplicitDateRange
* GetModel_Or_Asset_Alarms.groovy
* Returns assets with organizations, alarms, and current mobile location.
* @params
* modelName (OPTIONAL) Str - the name of the model to retrieve assets
* assetId (OPTIONAL) Long - the id of the asset - one of the two is REQUIRED
* @author sara streeter <sstreeter@axeda.com>
* initialize our global variables
* json = the contents of our response
* infoString = a stringBuilder used to collect debug information during the script
* contentType = the content type we will return
* scriptname = The name of this Script, used in multiple places
def json = new groovy.json.JsonBuilder()
def infoString = new StringBuilder()
def contentType = "application/json"
def scriptName = "GetModel_Or_Asset_Alarms.groovy"
def root = [:]
def timings = [:]
timings.dataItemList = 0
timings.currentdata = 0
timings.histdata = 0
timings.wholescript = 0
timings.alarms = 0
timings.loop = 0
timings.filter = 0
timings.devices = 0
timings.geocode = 0
wholestart = System.currentTimeMillis()
final def Context CONTEXT = Context.getSDKContext()
def deviceList
List<Device> devices
try {
    /* BUSINESS LOGIC GOES HERE */
    def modelName = Request.parameters.modelName
    def assetId
    def alarms
    AlarmFinder alarmFinder = new AlarmFinder(CONTEXT)
    if (Request.parameters.assetId != null && Request.parameters.assetId != ""){
        assetId = Request.parameters.assetId
        DeviceFinder deviceFinder = new DeviceFinder(CONTEXT, new Identifier(assetId as Long));
        def device = deviceFinder.find()
        if (device){
            alarmFinder.setDevice(device)
            modelName = device.model.name
    else if (modelName){
        try{
        modelName = new URLDecoder().decode(modelName)
        catch(e){ logger.info(e.localizedMessage) }
        if (modelName != null && modelName !=""){
            ModelFinder modelFinder = new ModelFinder(CONTEXT)
            modelFinder.setName(modelName)
            Model model = modelFinder.find()
            if (model){
                modelName = model?.name
                alarmFinder.setModel(model)
    alarms = alarmFinder.findAll()
    // build the json from the models
         root = [
             "result": [
             "model": modelName,
             "assetId": assetId,
             "alarms":alarms?.inject([]){ aList, alarm ->
                   aList << [
                        "deviceId": alarm.device?.id?.value,
                       "deviceName": alarm.device.name,
                       "deviceSerial": alarm.device.serialNumber,
                        "name": alarm.name,
                        "id": alarm.id.value,
                        "state": alarm.state.name,
                        "description": alarm.description,
                        "severity": alarm.severity,
                        "timestamp": alarm.date.time
                  aList
    /* BUSINESS LOGIC ENDS HERE */
} catch (Exception e) {
    def errorCode = "123456"
    processException(scriptName,json,e,errorCode)
finally {
    timings.wholescript = System.currentTimeMillis() - wholestart
    root += [params: Request.parameters]
    root += [timings: timings]
return ['Content-Type': 'application/json', 'Content': JSONObject.fromObject(root).toString(2)]
* ACTIVE CODE ENDS HERE
* HELPER METHODS START BELOW
* Wrap-up the response in our standard return map
* @param contentType The global contentType variable
* @param response The contents of the response (String ONLY)
private def createReturnMap(String contentType, String response) {
    return ["Content-Type": contentType,"Content":response]
    Processes the contents of an Exception and add it to the Errors collection
    @param json The markup builder
private def processException(String scriptName, JsonBuilder json, Exception e, String code) {
    // catch the exception output
    def logStringWriter = new StringWriter()
    e.printStackTrace(new PrintWriter(logStringWriter))
    logger.error("Exception occurred in ${scriptName}: ${logStringWriter.toString()}")
        Construct the error response
        - errorCode Will be an element from an agreed upon enum
        - errorMessage The text of the exception
    json.errors  {
        error {
            errorCode   "${code}"
            message     "[${scriptName}]: " + e.getMessage()
            timestamp   "${System.currentTimeMillis()}"
    return json
    Log a message. This will log a message and add it to info String
    @param logger The injected logger
    @param scriptName The name of the script being executed
    @param info The infoString to append to
    @param message The actual message to log
private def logMessage(def logger, String scriptName, StringBuilder info, String message) {
    logger.info(message)
    info.append(message+"\n")
    Audit a message. This will store a message in the Audit log, based on the supplied category.
    @param category The category for this audit message. One of: "scripting", "network", "device" or "data". Anything not recognized will be treated as "data".
    @param message The actual message to audit
    @param assetId If supplied, will associate the audit message with the asset at this ID
private def auditMessage(String category, String message, String assetId) {
    AuditCategory auditCategory = null
    switch (category) {
        case "scripting":
            auditCategory = AuditCategory.SCRIPTING;
            break;
        case "network":
            auditCategory = AuditCategory.NETWORK;
            break;
        case "device":
            auditCategory = AuditCategory.DEVICE_COMMUNICATION;
            break;
        default:
            auditCategory = AuditCategory.DATA_MANAGEMENT;
            break;
    if (assetId == null) {
        new AuditMessage(Context.create(),"com.axeda.drm.rules.functions.AuditLogAction",auditCategory,[message]).store()
    } else {
        new AuditMessage(Context.create(),"com.axeda.drm.rules.functions.AuditLogAction",auditCategory,[message],new Identifier(Long.valueOf(assetId))).store()
def findOrCreateExtendedMap(String name){
       // should take a name of Extended Map and output an object of type Extended Map, if it outputs null we throw an Exception
       def outcome = [:]
       outcome.extendedMap
       ExtendedMap extendedMap = extendedMapBridge.find(name)
       if (!extendedMap){
            extendedMap = new ExtendedMap(name: name)
           extendedMapBridge.create(extendedMap)
       if (extendedMap) {
        ExecutionResult result = new ExecutionResult()
        result.setSuccessful(true)
        result.setTotalCount(1)
        outcome.result = result
        outcome.extendedMap = extendedMap
       else {
           result.setSuccessful(false)
        return outcome
   def retrieveModels(){
      // retrieves the list populated by a separate script
       def outcome = [:]
       outcome.modelList
       ModelCriteria modelCriteria = new ModelCriteria()
       modelCriteria.type = ModelType.STANDALONE
       FindModelResult modelResult = modelBridge.find(modelCriteria)
       if (modelResult.models.size() > 0){
        outcome.modelList = modelResult.models
       else {
        return outcome
   def returnModelsWithAssets(List<com.axeda.services.v2.Model> modelList){
       def outcome = [:]
       outcome.modelList
       outcome.message
       if (!modelList || modelList?.size() ==0){
          outcome.message = "returnModelsWithAssets: Model list was not supplied or was of size zero."
          return outcome
       DeviceFinder deviceFinder = new DeviceFinder(CONTEXT)
       List<com.axeda.drm.sdk.device.Model> sortedList = modelList.inject([]){ target, amodel ->
            modelFinder.setName(amodel.modelNumber)
           com.axeda.drm.sdk.device.Model bmodel = modelFinder.find()
           deviceFinder.setModel(bmodel)
           def numAssets = deviceFinder.findAll().size()
           if (numAssets > 0 ){
                  target << bmodel
            target
       }.sort{ amodel, bmodel ->  amodel.name <=> bmodel.name}
       if (sortedList.size() > 0){
        outcome.modelList = sortedList
       else {
        return outcome
    def addMapEntry(String mapName, String key, String value){
       def outcome = [:]
        outcome.key
        outcome.value
        ExecutionResult result = extendedMapBridge.append(mapName, key, value)
        if (result.successful){
            outcome.key = key
            outcome.value = value
        return outcome
Version history
Last update:
‎May 25, 2016 11:28 AM
Updated by:
Labels (2)
