This Groovy script is called from an ExpressionRule of type Alarm. For example, in an Expression rule
IF: Alarm.severity > 500
THEN: ExecuteCustomObject("SMSMe", "[numberToSMS]")
calls the script "SMSMe" with the parameter phoneNumber. The ExecuteCustomObject provides a way to call from this simple two-line business rule into a modern programming environment with access to the complete Platform SDK, as well as all the features of the Groovy language. In Groovy, it's straightforward to use the built-in httpclient library to POST an HTTP request to Twilio to send an SMS to the specified cellphone number.
The groovy script named SMSMe is executed by the Expression Rule above and connects to the Twilio Server passing in a list of parameters.
When you register with Twilio, you will be given an ACCOUNT SID (apiID) and an AUTH TOKEN (apiPass). These two strings need to be in the Groovy Script below:
String apiID = 'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX'
String apiPass = 'AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA'
Variable Name Display Name
phoneNumber phoneNumber
import org.apache.commons.httpclient.Credentials
import org.apache.commons.httpclient.HostConfiguration
import org.apache.commons.httpclient.HttpClient
import org.apache.commons.httpclient.UsernamePasswordCredentials
import org.apache.commons.httpclient.auth.AuthScope
import org.apache.commons.httpclient.methods.GetMethod
import org.apache.commons.httpclient.methods.PostMethod
import org.apache.commons.httpclient.NameValuePair
//logger.info "Calling ${parameters.phoneNumber}"
String twilioHost = 'api.twilio.com'
String aipPass = 'AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA'
HostConfiguration hc = new HostConfiguration()
hc.setHost(twilioHost, 443, "https")
def url = "/2008-08-01/Accounts/$apiID/SMS/Messages"
def client = new HttpClient()
Credentials defaultcreds = new UsernamePasswordCredentials(apiID, aipPass)
client.getState().setCredentials(null, null, defaultcreds)
PostMethod post = new PostMethod(url);
post.addParameter 'IfMachine', 'Continue'
post.addParameter 'Method', 'POST'
post.addParameter 'From', '[YourNumber]'
post.addParameter 'To', parameters.phoneNumber
post.addParameter 'Body', 'This is an SMS from Axeda'
client.executeMethod(hc, post);
//logger.info message = "Status:" + post.getStatusText()
//logger.info post.getResponseBodyAsString()
post.releaseConnection();
