Axeda Groovy Script: Update properties on a model
nishanair
Update properties on a model.
Parameter:
  1. modelName (REQUIRED) - String - the name of the model to have its properties updated.
import com.axeda.drm.sdk.device.DeviceProperty
import com.axeda.drm.sdk.device.ModelFinder
import com.axeda.drm.sdk.Context
import com.axeda.drm.sdk.device.DevicePropertyFinder
import com.axeda.drm.sdk.device.Property
import com.axeda.drm.sdk.device.PropertyType
import com.axeda.common.sdk.id.Identifier
Set<String> REQUIRED_PROPERTIES = [
    "TestProperty0","TestProperty1","TestProperty2"
try {
    final def Context CONTEXT = Context.getSDKContext()
    ModelFinder modelFinder = new ModelFinder(CONTEXT);
    modelFinder.setName(parameters.modelName)
   Model model = modelFinder.find();
   if (model == null){ throw new Exception("No model found") }
   modelProperties = findModelProperties(CONTEXT, model.id)
    updateProperties(CONTEXT, model.id, modelProperties, REQUIRED_PROPERTIES)
    modelProperties.properties.each{ logger.info("$it.name :$it.value") }
catch (Exception e){
    logger.info e.localizedMessage
return true
private DeviceProperty findModelProperties(Context context, Identifier modelID) {
  def finder = new DevicePropertyFinder(context)
  finder.id = modelID
  finder.type = PropertyType.MODEL_TYPE
  return finder.findOne() as DeviceProperty
private void updateProperties(Context context, Identifier modelID, DeviceProperty modelProperties, Set<String> requiredProperties) {
  if (!modelProperties) {
    modelProperties = new DeviceProperty(context)
    modelProperties.id = modelID
    modelProperties.type = PropertyType.MODEL_TYPE
    modelProperties.properties = []
  (requiredProperties - new HashSet<String>(modelProperties.properties.collect { it.name })).inject(modelProperties.properties) { list, propertyName -> list << new Property(0, propertyName, "") }
  modelProperties.store()
0 REPLIES 0
