Axeda: Helper Functions for Extended Objects
nishanair
This is a collection of methods for working with ExtendedObjects based on the functions used in Fleetster.
import com.axeda.drm.sdk.device.Device
import com.axeda.platform.sdk.v1.services.ServiceFactory
import com.axeda.platform.sdk.v1.services.extobject.ExtendedObjectSearchCriteria
import com.axeda.platform.sdk.v1.services.extobject.PropertySearchCriteria
import com.axeda.platform.sdk.v1.services.extobject.expression.PropertyExpressionFactory
import com.axeda.drm.sdk.data.CurrentDataFinder
import java.text.DecimalFormat
import com.axeda.drm.sdk.Context
import com.axeda.drm.sdk.device.DeviceDataFinder
import com.axeda.drm.sdk.user.User
import com.axeda.platform.sdk.v1.services.extobject.ExtendedObjectService
import com.axeda.platform.sdk.v1.services.extobject.PropertyType
import com.axeda.platform.sdk.v1.services.extobject.PropertyDataType
import com.axeda.platform.sdk.v1.services.extobject.ExtendedObjectType
import com.axeda.common.sdk.id.Identifier
import groovy.time.*
/* HelperFunctionsExtendedObjects.groovy
* Extended Object retrieval/manipulation functions.
* A collection of methods for working with ExtendedObjects.
* author: sara streeter <sstreeter@axeda.com>
    def eoSvc = new ServiceFactory().getExtendedObjectService()
    def fetchFirstExtendedObject(DataItem dataItem, Map searchcriteria) {
        def criteria = new ExtendedObjectSearchCriteria()
        criteria.extendedObjectClassName = 'com.axeda.drm.sdk.device.DataItem'
        criteria.internalObjectId = dataItem.id.value
        criteria.extendedClientKey = "ExtendedDataItem!${dataItem.name}"
        def eo
      if (searchcriteria != null){
            criteria.propertySearchCriteria = advancedPropertySearch(searchcriteria)
       def queryResult = eoSvc.findExtendedObjects(criteria,  -1, -1, null)
        if (queryResult.size() > 0 ){
        eo = queryResult.first()
       return eo
   def addOrFetchExtendedDataItem(DataItem dataItem, Map searchcriteria) {
        def eo
       if (queryResult.size() == 0 || queryResult == null){
              eo = new ExtendedObject()
              eo.internalObjectId = dataItem.id.value
              eo.extendedObjectType = eoSvc.findExtendedObjectTypeByClassname('com.axeda.drm.sdk.device.DataItem')
              eo.externalClientKey = "ExtendedDataItem!${dataItem.name}"
              eo = eoSvc.createExtendedObject(eo)
            searchcriteria += [eotype: "ExtendedObject"]
            createProperties(eoSvc, eo, searchcriteria)
        else eo = queryResult.first()
       return eo
   def fetchExtendedDataItem(DataItem dataItem) {
        criteria.extendedObjectClassName = "com.axeda.drm.sdk.device.DataItem"
        return queryResult
   def fetchExtendedObjectsAdvancedCriteria(DataItem dataItem, Map searchcriteria, String classname, String uniqueKey) {
        return queryResult
   def fetchExtendedObject(User user, Map searchcriteria) {
        criteria.extendedObjectClassName = "com.axeda.drm.sdk.user.User"
        criteria.extendedClientKey = "ExtendedObject!${user.username}"
        criteria.internalObjectId = user.id.value
        criteria.propertySearchCriteria = exactdatePropertySearch(searchcriteria)
        return queryResult
   def addExtendedObject(String eoTypeName, Long referenceId, String referenceName, Map objectProperties) {
      def eo = new ExtendedObject()
      eo.internalObjectId = referenceId
      eo.extendedObjectType = eoSvc.findExtendedObjectTypeByClassname(eoTypeName)
      eo.externalClientKey = referenceName
      eo = createProperties(eoSvc, eo, objectProperties)
       return eo
   def updateExtendedObject(ExtendedObject ExtendedObject, ExtendedObject ExtendedObject) {
                def ExtendedObjectprop = getProperties(ExtendedObject)
                def newproperties = [:]
                if (ExtendedObjectprop.timestamp != null){
                def ExtendedObjecttype = ExtendedObjectprop.lasttype
                def ExtendedObjecttime = ExtendedObjectprop.lasttime
                if (ExtendedObjecttype == null){
                    newproperties["lasttype"] = ExtendedObjectprop.type
                    newproperties["lasttime"] = ExtendedObjectprop.timestamp
                else {
                    def oldtime = Long.valueOf(ExtendedObjecttime)
                    def total = (Long.valueOf(ExtendedObjectprop.timestamp) - oldtime)/1000
                    // illustrating getPropertyByName /
                    def lasttype = ExtendedObject.getPropertyByName("lasttype")
                    lasttype.setValue(ExtendedObjectprop.type)
                    def lasttime = ExtendedObject.getPropertyByName("lasttime")
                    lasttime.setValue(ExtendedObjectprop.timestamp)
                    updateProperty(lasttype)
                    updateProperty(lasttime)
                    if (ExtendedObjectprop.containsKey(ExtendedObjecttype + "_total")==false)
                            newproperties[ExtendedObjecttype + "_total"] = total
                    else {
                        def totalprop = ExtendedObject.getPropertyByName(ExtendedObjecttype + "_total")
                        def lasttotal = Double.valueOf(totalprop.value)
                        totalprop.setValue(String.valueOf(Double.valueOf(total) + lasttotal))
                        updateProperty(totalprop)
                if (newproperties.size() > 0){
                    ExtendedObject = createProperties(eoSvc, ExtendedObject, newproperties)
        return ExtendedObject
    def getProperties(ExtendedObject object){
        def result = object.properties.inject([:]) { target, property ->
              target += [(property.propertyType.name): castPropertyValueToDefinedType(property)]
        return result
    def formatProperties(Map properties){
        def result = properties.collect { property, value ->
               [type: property, time: value]
        return result
def updateProperty(Property property){
        eoSvc.updateProperty(property)
        return property
    //default string version
    def createProperties (ExtendedObjectService eoSvc, ExtendedObject object, Map properties) {
        return createProperties(eoSvc, object, properties, PropertyDataType.String)
    //WARNING: PDT may not work if it's a Date; it hasn't been tested.
    def createProperties (ExtendedObjectService eoSvc, ExtendedObject object, Map properties, PropertyDataType PDT) {
       // http://groovy.codehaus.org/Operators#Operators-ElvisOperator
        PDT = PDT?:PropertyDataType.String
        properties.each { k , v ->
            def property = new com.axeda.platform.sdk.v1.services.extobject.Property()
            def propertytype = object.extendedObjectType.getPropertyTypeByName(k.toString())
            if (propertytype == null){
                def newPropertyType = new PropertyType()
                newPropertyType.name = k
                newPropertyType.dataType = PDT
                newPropertyType.extendedObjectType = object.extendedObjectType
                eoSvc.createPropertyType(newPropertyType)
                property.propertyType = newPropertyType
            } else { property.propertyType = propertytype }
            property.value = (PDT == PropertyDataType.Date && v instanceof Date?v.format("yyyy-MM-ddTHH:mm:ssZ"):v.toString())
            eoSvc.createPropertyOnExtendedObject(object, property)
        object = findExtendedObjectById(object.id)
        return object
    def findExtendedObjectById(Long id){
        criteria.id = id
        return queryResult.first()
    def findObjectByNextPropertyValue (ExtendedObject object, Map criteria, PropertySearchCriteria psCriteria){
       Property prop = object.getPropertyByName(criteria.incrementName)
       def incrementedProp = prop.value.toInteger() + criteria.incrementValue.toInteger()
           psCriteria.setPropertyExpression(
           PropertyExpressionFactory.and(
                    psCriteria.propertyExpression,
                    PropertyExpressionFactory.eq(criteria.incrementName, incrementedProp.toString())
       def eoCriteria = new ExtendedObjectSearchCriteria()
        eoCriteria.extendedObjectClassName = "com.axeda.drm.sdk.user.User"
        eoCriteria.internalObjectId = object.internalObjectId
        eoCriteria.propertySearchCriteria = psCriteria
       def queryResult = eoSvc.findExtendedObjects(eoCriteria,  -1, -1, null)
    def advancedPropertySearch (Map searchcriteria){
          def propCriteria = new PropertySearchCriteria()
       propCriteria.setPropertyExpression(
               PropertyExpressionFactory.eq("year", searchcriteria.year),
                        PropertyExpressionFactory.eq("month", searchcriteria.month),
                                    PropertyExpressionFactory.eq("date", searchcriteria.date)
        return propCriteria
  static def extendedObjectToMap(ExtendedObject object) {
    Map result = [:]
    result.extendedObjectType = object?.extendedObjectType?.className
    result.extendedObjectTypeId = object?.extendedObjectTypeId
    result.id = object?.id
    result.externalClientKey = object?.externalClientKey
    result.internalObjectId = object?.internalObjectId
    // build up the properties of the ExtendedObject.
    result.properties = object?.properties.inject([:]) { target, property ->
      target += [(property?.propertyType?.name): castPropertyValueToDefinedType(property)]
    return result
      static def extendedObjectTypeToMap(ExtendedObjectType objectType) {
        Map result = [:]
        result.className = objectType.className
        result.id = objectType.id
        result.displayName  = objectType.displayName
        result.userDefined = objectType.userDefined
        result.description = objectType.description
        result.properties = objectType.propertyTypes.inject([]) { List list, PropertyType propertyType ->
          list << [
                  description: propertyType.description,
                  dataType: propertyType.dataType.toString(),
                  extendedObjectType: propertyType.extendedObjectType.className
        return result
      private static def castPropertyValueToDefinedType(Property property) {
        switch(property.propertyType.dataType) {
          case PropertyDataType.Boolean:
            return property.value as Boolean
          case PropertyDataType.Date:
            Calendar calendar = javax.xml.bind.DatatypeConverter.parseDateTime(property.value)
            return calendar.getTime()
          case PropertyDataType.Double:
            return property.value as Double
          case PropertyDataType.Integer:
            return property.value as Long
          case PropertyDataType.String:
          default:
      static def removeExtendedObject(Long itemId) {
        eoSvc.deleteExtendedObject(itemId)
      def removeUserExtendedObjects(User user) {
        def queryresult = fetchUserExtendedObjects(user)
        queryresult.each{
                eoSvc.deleteExtendedObject(it.id)
  ExtendedObjectType findExtendedObjectType(String typeName) {
    ExtendedObjectType userObjType = eoSvc.findExtendedObjectTypeByClassname(typeName)
    return userObjType
  ExtendedObjectType findOrCreateExtendedObjectType(String typeName) {
    ExtendedObjectType type = findExtendedObjectType(typeName)
    if (type == null) {
      type = new ExtendedObjectType()
      type.className = typeName
      type.displayName = typeName
      type.description = "Autocreated type for $typeName"
      type = eoSvc.createExtendedObjectType(type)
    return type
0 REPLIES 0
