Calling a Groovy script as an External Web Service
Garnet
This script illustrates how to call a Groovy script as an external web service.  This example also applies to calling any external web service that relies on a username and password.
Parameters:
  1. external_username
  2. external_password
  3. script_name
import com.axeda.drm.sdk.Context
import com.axeda.drm.sdk.device.DeviceFinder
import com.axeda.drm.sdk.data.CurrentDataFinder
import com.axeda.drm.sdk.data.HistoricalDataFinder
import com.axeda.drm.sdk.device.DataItem
import net.sf.json.JSONObject
import com.axeda.drm.sdk.device.ModelFinder
import groovyx.net.http.*
import static groovyx.net.http.ContentType.*
import static groovyx.net.http.Method.*
* CallScriptoAsExternalWebService.groovy
* This script illustrates how to call a Groovy script as an external web service.
* @param external_username       -   (REQ):Str Username for the external web service.
* @param external_password       -   (REQ):Str Password for the external web service.
* @param script_name             -   (REQ):Str Script Name to call.
def result
try {
validateParameters(actual: parameters, expected: ["external_username", "external_password", "script_name"])
// authentication tokens (username + password)
def auth_tokens = [username: parameters.external_username, password: parameters.external_password]
http = new HTTPBuilder( 'http://platform.axeda.com/services/v1/rest/Scripto/execute/'+parameters.script_name )
// pass in dummy parameters to the script for illustration
def parammap = [key1: "val1", key2: "val2"]
// Call the script
    http.request (GET, JSON) {
      uri.query = auth_tokens + parammap
      response.success = { resp, json ->
        // traverse the wrapped json response
    result = json.wsScriptoExecuteResponse.content.$
      response.failure = { resp ->
        result = response.failure
} catch (Throwable any) {
    logger.error any.localizedMessage
return ['Content-Type': 'application/json', 'Content': result]
static def validateParameters(Map args) {
    if (!args.containsKey("actual")) {
        throw new Exception("validateParameters(args) requires 'actual' key.")
    if (!args.containsKey("expected")) {
        throw new Exception("validateParameters(args) requires 'expected' key.")
    def config = [
            require_username: false
    Map actualParameters = args.actual.clone() as Map
    List expectedParameters = args.expected
    config.each { key, value ->
        if (args.options?.containsKey(key)) {
            config[key] = args.options[key]
    if (!config.require_username) { actualParameters.remove("username") }
    expectedParameters.each { paramName ->
        if (!actualParameters.containsKey(paramName) || !actualParameters[paramName]) {
            throw new IllegalArgumentException(
                    "Parameter '${paramName}' was not found in the query; '${paramName}' is a reqd. parameter.")
Tags (1)
