Comparison of ThingWorx Database Options (taken from KCS Article CS257403)
Highlighted
Level 6
  • Embedded databases come with the installation of the ThingWorx Platform
    • No additional installation or configuration is required for embedded databases
    • Read about the various benefits and pitfalls of embedded versus external below
  • Database Options
    • H2
      • RDBMS (relational database management system), written in Java
      • Has a small memory footprint
      • Embedded into ThingWorx for easy installation
      • Not as robust as other database options
      • Not scalable in production environments (unless used alongside a separate, external database for stream, value stream, and other data) ​
        • See KCS Article CS243975 for further reading on the use of external databases
      • Meant to be used for quick deployments and testing environments
    • PostgreSQL
      • ORDBMS (object-relational database management system), written in C
      • PostgreSQL is the ThingWorx recommended database for production systems
      • More Robust
        • External database installed separately from ThingWorx
        • Beneficial because external databases can be specifically configured for use in production, while embedded databases cannot
        • Able to efficiently handle larger amounts of data and store more data without affecting ThingWorx system performance
      • Greater Stability
        • Recover from data corruptions more easily by accessing the database from an external application (separate from ThingWorx) using simple SQL statements
        • Easier to back-up the database in case of issues (further reading in KCS Article CS246598)
        • Less risky and simpler upgrade procedure, which occurs "in-place"
          • Instead of exporting and importing data and entities, a simple schema update allows these to automatically persist into the new version
          • If ThingworxStorage folder is accidentally deleted, entities and data are secure in the external database
      • More Secure
        • HA (High Availability) allows for multiple server instances at different locations in the network
          • Assists in time of failover, i.e. if one server fails, the other can immediately take over
          • Secures the data and prevents further data loss in the event of a failure
        • Customizable security settings and complex password requirements
        • Fewer security vulnerabilities than other databases
      • Because Postgres is an external database, it can be harder to install
        • Follow the steps in the installation guide closely
        • See KCS Articles CS235937 and CS230085 for troubleshooting and help with installation and configuration
    • Hana
    • Neo4J
      • GDBMS (graph database management system), written in Java
      • Data is not easily accessed by external applications, and CQL must be used instead of SQL, making recovery from corruptions very difficult
      • Embedded database with limited configuration options
      • Known to have issues with deadlocks
      • Deprecated in version 7.0 (related KCS Article: CS228537)
  • For full installation steps for H2 and PostgreSQL, see the ThingWorx Installation Guide
