It should be noted that ThingWorx supported database options (model and data) have evolved to best fit with our customers requirements. Going forward you should be looking at either PostgreSQL or Microsoft SQL (or Azure PaaS versions of both), and InfluxDB for high-volume/speed time-series data ingestion.
